Driveshaft Spacer Install Guide
Im doing this now, using 2pc spacers, and I cant get the top 2 bolts off on each side. I took the exhaust off for the passenger side, but there still isnt enough room to get up there, any suggestions?
Originally Posted by zacs2K,Aug 14 2009, 11:43 AM
1 pc design will allow for better balance and less axel vibration.
great story I got a feeling you've never seen a set
The tolerances on 2pc spacers are too tight to produce any kind of unbalance due to weight or size. I couldn't measure a difference between both pieces to a fraction of a mm
want some pics? need me to take a pic of them on a scale for you? I can let you borrow a set and see if the vibrations won't brighten up your day
whats the benefit to running these spacers? 1 piece or 2 piece? whats a good 2 piece spacer to get anyway? sorry for being noob im learning slowly
Guys. Hope you read to the bottom. Don't need to undo the top arm. Pop the bottom ball joint off and it gives you mire than enough room to pull out the half shaft to install. Much easier and a lot faster.
bobby.is.rad
08-24-2012 04:35 PM
marlonRocks
12-27-2007 08:51 AM
