Driveshaft removal tips?
1 Post
If you dremel a couple of them, some of the others will loose a little tension and will come out with a allen wrench (stripped sockets an all). With the driveshaft gone, you can grab the remaining stumps of bolts with visegrips. They will unscrew easily as there will be no torque on them. At least thats the way mine went.
I soak mine for a couple hours in pb blaster and use an imparct to get them out. You don't have to lower anything at all just use the parking brake and twist the driveshaft as you need and reapply the parking brake. If you cut the heads off you can heat the bolts and vice grip them off. They are a softer metal by design. Puddydaddy usually has some stronger bolts if thats what you are looking for.
Heat doesn't work? Get it glowing red, it'll come out.
Well... unless there's something nearby that will be ruined by a torch.
I'm still new to this car.
thanks guys i actually tried everthing you guys said and the only one that worked was cutting the heads off. Thanks for all the responses i dont know what i would do without you guys lol. Last question tho...im reinstalling a new diff. i just had a question on how to get both wheel driveshafts into the diff at the same time. They only compress about an inch if that and they are impossible to get in. I can get one but the other side wont clear im not sure what to do?
Originally Posted by Motoxer4life,Jul 5 2010, 09:03 PM
Damn i looked for a 4 inch one and cant find it anywhere? Any specific place you went for yours man?
1 Post
Originally Posted by Motoxer4life,Jul 7 2010, 11:30 AM
Hmm how hard is that to do blag? Sorry about all the questions guys i havent worked too much on this car yet
redwing497
12-05-2015 11:06 PM
