driver side seat belt!!!! will my airbag still go off???
i have brides and i have harnesses with them. i no longer have the oem belts in the car. so the little clip on the bottom of the seat that sets off the light when your belt is not clipped in is not attachted anymore. will that affect my airbag deployment at all? or does it not matter? thanks
Drive Safe,
Steve R.
FMVSS 208 (name for USDM car crash law) dictates that unbelted occupants of the vehicle should have a specified level of protection offered through advanced technology airbags. This means that the airbag will deploy, even if no 'latched seatbelt' signal is present.
Regards,
Siepel
Regards,
Siepel
Regards,
Siepel
Regards,
Siepel
The plug under the seat has nothing to do with the airbag. It is the connection that allows actuation of the seatbelt warning light and chime.
I hope that you have installed the harness properly and have added a rollbar to go along with your harness. It is critical that the shoulder belt mount points are level or only slightly below the shoulder. Otherwise you can experience serious compression injury to your spine in the event of a frontal impact. The rollbar is necessary to protect your head in the event of a rollover. Please be safe!
Drive Safe,
Steve R.
In an open car it is considered acceptable to have the shoulder strap route backwards from the shoulder at up to a 15 degree angle downward. This helps keep the occupant in the car and does not substantively contribute to spinal compression in a frontal impact. If the shoulder strap leaves the shoulder at an upward angle, it does a less effective job at keeping the occupant in the seat in the event of a rollover.
The gross error that some people make when mounting harnesses in the S2000 is to wrap the shoulder strap over the shoulder and then down to the floor. This can lead to serious injury through spinal compression in the event of frontal impact, and is the main reason for my concern. I've also seen some people wrap the shoulder straps around the cosmetic plastic around the stock roll hoops. The plastic will crush if there's a severe frontal impact, resulting in excessive forward travel and greatly increased risk of injury.
