Driveability Issues with Lightweight Flywheels
#31
Originally Posted by Saki GT' timestamp='1301584075' post='20415731
F=m*a - If you remove mass from the flywheel, you will need to increase acceleration from the engine to get the same force. With less mass, acceleration inputs, either from you or from the connected transmission, play a bigger role.
it should be noted here that it's not just the flywheel that affects these things. it's bolted to the pressure plate as well, and some clutch systems include ultra lightweight pressure plates. in theory, you could get the same effects by lightening the pressure plate instead of the flywheel. anyway, i drove a Carbonetic single clutch, and i think that system has the lightest flywheel + pressure plate combination available (~17lbs!!!!). as soon as you push in the clutch, the revs drop to the floor. you basically have no time to shift. just tap the clutch while moving the lever. best shifting system ever.
the carbonetic clutch is an extreme example of the effects of a lightened flywheel. but some people can't handle that quickness.
#32
Some people don't want to deal with that in a daily driver; you know, the folks that don't live their lives a quarter mile at a time. Its important to know what making changes will do elsewhere, something too many people never think about.
#33
Thanks slipstream for getting specific - I was trying to simply point out conservation of energy principle - in general, there is always an effect to a change somewhere in the system. Whether or not its noticeable or better or worse, that's different. There are many variables to consider along the way too.
