Drive By Wire Throttle - Is it in the '04+ s2k?
Old 11-05-2004, 04:17 AM
Slows2k's Avatar
Originally Posted by AusS2000,Nov 5 2004, 07:46 AM
This is a bit of a falsehood. The only place in the world where the S2000 comes with cruise control is in north America so it's not really a necessity. In fact the only thing in that list that is actually required for a conventional throttle is the cable.
Drive By Wire Throttle is one of those sophistications that remove the burden of driving from the guy behind the wheel. When you think about the spirit of the S2000 the last think you want to do away with is that experience.
One of the repeated themes in the S2000 is the use of the best of established technology (like the 6 speed gearbox, rather than implementing immature technologies (such as paddle shifts). That's what makes the S2000 so good at what it does.
Aus, I didn't mean to say that theses systems are required, especially on a S2000. Most cars here are expected to have these systems. All these lazy Americans get a little pissy without them.
For cars that do have Traction control and Cruise it takes less overall components to run a throttle by wire.
I still think it's quite silly that manufacturers have figured out a very elaborate electronic means to replace a cable.
Old 11-05-2004, 07:46 AM
sebrings2k's Avatar
I'd go test drive a 350Z to get a feel for what its like.
Old 11-06-2004, 07:25 AM
spoiled@21's Avatar
Bimmer has put drive by wire systems in the M3 (e46) and the upcoming M5. The advantage that you get with the BMW systems is the sport mode button next to the shift lever. It allows for "sport" mode which increase the sensitivity if the throttle pedal to allow for a sportier feel. However with the sport button off it is a much more docile beast around town. Corvette has had TBW for sometime as well as most of the italians. If you have TBW you can put more buttons in your console and people apparently like lots of buttons.
Old 11-06-2004, 09:58 AM
Banned
Tugz_S2K's Avatar
DBW has many advantages. The first Honda to use the DBW is in the 03 Acura MDX. Some of the advantages of DBW is complete control of the fuel and air management by the computer. Cruise control units can be eliminated and incorporated in the ECU programming the same thing can be said about traction control and Stability programming.... it allows the ECU to override throttle inputs of the driver in conditions when traction control, cruise control and/or electronic stability program is used.
Old 11-06-2004, 01:07 PM
Slows2k's Avatar
Sorry, that's incorrect. The 95 NSX was 1st with DBW
Old 11-06-2004, 03:58 PM
Banned
Tugz_S2K's Avatar
i stand corrected then
Old 11-07-2004, 06:16 AM
Spankee's Avatar
That is incorrect also, NSX has had DBW ever since its introduction in 1991.
Old 11-07-2004, 07:33 AM
Slows2k's Avatar
Check here:
http://www.nsxprime.com/FAQ/General/changesbyyear.htm
95 is the 1st year. The people that convert OBDII NSX's to AEM EMS have to swap the throttle body, cables and pedal assembly beacause a OBDII compatible EMS that supports DBW doesn't exist yet.
Old 11-07-2004, 09:12 AM
slipstream444's Avatar
Another aspect of DBW that I'm surprised hasn't been discussed here yet is that it makes a so equipped car easier to disable via external means. I know this sounds a bit like 'big brother' paranoia ... but it's not meant that way.
Technologies like DBW that have been filtering into cars over the past couple of decades will allow developed and future law enforcement technologies to shut your car down electronically - without frying the cars ECU. This is not to say law enforcement will be the only ones with the toys though.
This is a good thing if your car has just been stolen...
The bad side: well there are probably several thousand opinions on that side of the coin. Just a side note.
Old 11-09-2004, 04:28 PM
mtm584's Avatar
The drive by wire is just another delhpi corp product designed to make the percentage of there products in the auto industry higher, because they plan by the year 2010 that every car on the road has 40 percent of the products on board.
Quick Reply: Drive By Wire Throttle - Is it in the '04+ s2k?
