Dripping brake fluid from pedal
Hi guys the cylinder that's connects to the pedal is dripping brake fluid and my clutch pedal feels lighter then normal is that the clutch master cylinder or clutch slave cylinder that needs to be replaced
Take a turkey baster and remove all the [guaranteed to be dirty, black, gunky] brake fluid from the clutch reservoir under the hood.
Put new fluid in.
Bleed the clutch MC until new fluid comes out.
For bonus points while you're down there, sand and grease the nipple: https://www.s2ki.com/s2000/topic/370...-clutch-pedal/
Swap in new brake fluid and turkey baste your clutch fluid every oil change to keep it fresh and the problem should go away.
Put new fluid in.
Put new fluid in.
Put new fluid in.
If it is still leaking then the best option is to replace the master.
Define "shitty."
Your clutch master cylinder is likely to be done for. I had the same problem when I picked up my S. Just get a new one.
