Dremel tool to remove the axle nuts?
Old 08-11-2011, 04:34 AM
Billman250's Avatar
Received 1,338 Likes on 810 Posts
Jeezes christ, NO torch.
Get a 3/4 drive, and use a four foot pipe on it. It will come off, guaranteed. Do it with the car on the ground, work through the center cap hole.
Old 08-11-2011, 06:02 AM
zeroptzero's Avatar
Received 3,540 Likes on 2,543 Posts
how strong were the impact guns ?, you need about 300 ft lbs on the guns to get the nuts off, but they should come off easily with that and often unstake themselves.
Old 08-11-2011, 07:42 AM
Stratocaster's Avatar
You can always add the floor jack handle to the end of your breaker bar to extend the leverage.
Old 08-11-2011, 05:22 PM
Slows2k's Avatar
You are using baby impact wrenches and breaker bars. No need to un stake the nut.
Old 08-11-2011, 09:34 PM
skkppy's Avatar
it took a small flat head screw driver and a hammer and wedged it between the crimp and the notch and gently bent it out.... easy peazy
dulslo666
04-17-2009 06:58 AM
Pradamuimui
12-19-2004 06:42 PM
Quick Reply: Dremel tool to remove the axle nuts?
