Doors Lock Immediately
I researched this topic and found similar problems. The other day I got locked in my car. The lock switches inside the car don't unlock it. The key will unlock the passenger side only. When using the fob, the front door will unlock and the lock immediately. I can open the door by pulling the handle between the lock and unlock fraction of a second. Any help would be appreciated. The car is a stock '07.
Possibly try re-mating your fob with the system? If I were you (never been in this situation) I would unplug the battery-have your radio code ready first-
Let it sit for 5 minutes. Reconnect the battery
Get in the car, put the key in the ignition,
Turn to position 2, push unlock. Repeat 3 times turning to position zero but not removing the key between each time.
Take the key out, then put it back in the ignition.
turn to position 2, then press LOCK on your fob, turn to 0, then back to 2 press LOCK on fob again. repeat 3 times, may fix it, or might do nothing at all since the fob is for your car in the first place. But I know it resets the fob which could be glitching.
Maybe someone else will have a straight answer.
I just got done opening the door panel and found that the plastic piece the connects the inside manual locking switch to a metal rod inside the door was broken. I just ordered the inside door handle assembly which should fix the problem for about 40 bucks. I'll keep y'all posted.
