Dome light switch not working. Lights work
#111
Question.
Awesome post! The contacts in my S looked just like the ones in your picture. and after cleaning them, they work now when the door opens! But now, the lights wont go on when manually pressing the buttons, and they did before I took it apart. any idea what I may have done to cause this? the switch is in the middle position too.
Pop the light cover off.
Attachment 119500
Remove the two gold screws on each side of the fixture.
Attachment 119501
There are two small clips at the front of the light to pop off, then the light fixture comes down.
Attachment 119502
Remove the electrical connector
Attachment 119503
Take the fixture inside and remove the two gold screws holding the white thing down.
Attachment 119504
This is what mine looked like. It kinda worked when it wanted to.
Attachment 119505
Remove the slide switch but BE CAREFUL, it's easy to lose the little ball bearing detent balls.
Attachment 119506
I cleaned mine up with a brass brush in my Dremel at the lowest speed.
Attachment 119507
Works great now.
Attachment 119508
Attachment 119500
Attachment 119501
Attachment 119502
Attachment 119503
Attachment 119504
Attachment 119505
Attachment 119506
Attachment 119507
Works great now.
Attachment 119508
#112
Dome Light Issue
Fixed my dome light switch but when i install the left side screw, the lights brighten and can no longer go off/on with door switch. If i leave the screw out, it works perfectly, Any ideas?+
#113
windhund116 (12-26-2021)
