Dome Light problems
Dome Light problems
ok this will sound bizarre but today i was cruising at about 70kph and had to turn, which i took the corner at decent speed 40-50, and the dome light flicks on in the middle of the turn.
heres the crazier part.
country road, decide to let the engine come alive. once i hit vtec the dome light flicks on yet again. i couldnt believe it at first so i tried it again and same thing happened.
not sure if my car is alive or there is a connection problem. has anyone else had this problem before?
Never had the problem before, but it could be when your car vibrates with a certain resonance due to your engine/exhaust combination (you may not be stock)... you could be shorting two connects together that would normally be an open. Therefore whenever, whatever vibrates, it shorts wires together thus causing the light.
Who knows tho
Who knows tho
