doing maintenance
doing maintenance
I'm doing maintenance on my car and was wondering what else I should do. The s2k is a 2000 with 110,000 miles. I dd it and plan on driving 20-25,000 miles within the next year so taking care of the car is a must. heres my list so far please tell me if thiers anything else I should do. I got the car used so idk what tier log looked like and from the looks of it It even has the stock radiator hoses on it.
so far Ive...
replaced engine oil (moble 1 10w30)
replaced diff oil (amsoil 75w90)
replaced trans oil (honda mtf)
replaced radiator (cracked on me)
replaced spark plugs (iridiam)
replaced belt and idler pully (honda)
replaced thermostat (mugan), fan switch (mugan), rad cap (spoon)
replaced anifreeze (honda type 2)
replaced air filter (k&n)
to do...
clean iac
can you think of anything else a s2k with 110,000 miles needs?
so far Ive...
to do...
clean iac
I think you've replaced just about everything that's needed. I'd probably replace the radiator hoses since those are pretty old. might as well. get some shin-etsu grease and apply that to all of the rubber door seals, trunk, etc. jack up the car, check the brake pads and rotors, the brake hoses, check for any play in the wheel bearings, leaking shocks, etc.
hmm....possibly inspect retainers and adjust valves.Also,regrease cv buckets (redline grease) heard the original grease honda uses can liquefy.Search tsb axle nuts 220 ft.lbs. tq.grease and replace nut.Flush hydraulics,with new fluid ( brakes and clutch).Also,check for torque spec for the spark plugs,think it is now 19 ft lbs used to be 13 lbs but u better check to make sure.PCV also.
braeden
07-18-2015 12:54 AM
