doesnt wanna rev beyond 7k rpms!
i switch the car on, CEL comes on after 2-3seconds, but idle is fine and everything ok. i get moving, hit the throttle and when it hits around 7k+ rpm, it stops like a fuel cut: and this is if i go WOT. if i baby it, it reaches the top.
the CEL codes registered are not found in the manual, so my mech give spoon a call and states 99octane is the recommended fuel to use. but can lack of octane(i use 95) cause the engine to fuel cut at a certain rpm? need help badly...
any comments would be much appreciated. TIA
noted deathsled.
armthehomeless, yes it is used. i will try checking the maps out. thanks
last time i replaced anything were the o2 sensors. they were used as well. could that be the problem?
***i have a WTB thread out and i'm in the market for the primary and secondary ap1 02 sensors.
hi pinoyk20, didnt notice your post, sorry. its a jdm import. i live in the Philippines. makati city. are you in the PI?
im interested in your sensors. thanks!!!
***would anyone have any experience with fuel cut due to bad sensors???
I think that the octane rating has nothing to do with your problem. I do believe, however, that 95 is insufficient for any S2000. You should be up around 98 or 99 Research Octane, I believe. Check your owner's manual.
