does VAFC remember if you unplug the battery?
I never put much thought into this, but my car has a kill switch...you can kill the battery just in case i wreck it and my foot is still planted to the floor....
anyway... .i had the car dyno'd and tuned with the VAFC back in May..... since then the kill switch has been tested a handfull of times (luckily none of them with me wrecking or anything).....
does my little VAFC module keep it's settings even if the batter is unplugged?
thanks
thanks
You can adjust the air-fuel ratios for the selected RPM against a throttle possition.
In otherwords, At 4000 RPM at anything greater than 50% throttle, you can subtract the already rich 11:1 - 12:1 A/F ratio from Honda's ECU to something a little more efficient, say 13:1 - 14.7-1.
I'm just throwing numbers out there, the right way, (ONLY WAY) is to tune at the dyno.
-ryan
-ryan
