Does this sound like a bad starter?
if you hear the starter clicking, its trying to engage. A bad alternator will deplete a batteries life and it will test bad, regardless how new. In my experience working on vehicles, it takes about 8 hours to fully charge a dead battery. Most of the times when a battery is ran dry, its toast. Have a load test done on the alternator to make sure it is working. Most of the time the brushings wear out, but its easier to buy a new or rebuilt alt. instead of rebuilding it yourself. Hope this helps.
As far as my dead Kinetik, are you saying that I can still charge it? I asked Autozone to charge it for me and they tried but when I got it back, it was still dead. Should I try a trickle charger? The battery is like an Optima in that it is a sealed gel cell battery. So I don't know if it was run dry?
Originally Posted by s2kyo,Apr 15 2008, 05:36 AM
when you get your new battery.. start the car and while its running disconnect the battery and see if it continues to run while turning on the lights and tapping brakes and such.
if under that problem with charging system.
I picked up a new Optima Red Top (Group 34/78) which supposedly is for optimizing starting, and the car will not crank. The battery is fully charged, but when I try to start the car, it makes a steady mechanical sound kinda like the fuel pump priming but much louder. It does not simply click and does not turn over. It feels as though the starter motor itself is seized and cannot move the flywheel. I only tried a few seconds (to start) and both the positive and negative battery cables got pretty warm so I stopped. I'm thinking that the starter is somehow seized? I was planning on push starting it tonight, but not sure if this will damage the car assuming I have a seized starter. ..Any insight?
You can push start the car even with a bad starter. It sounds like you have a bad starter or the cables are loose on the starter. I would keep the battery cable disconnected in case the starter is shorted and causing a battery drain. You would know if it was because there would be a heavy spark when you disconnected the battery cable.
Well, I ended up buying a new starter even though the starter tested good at both autozone and advanced auto. I installed it this weekend and the car seems to be running great....although, I'm still a little gunshy about taking it for too long as I don't want to be stranded on the highway like before. While the car is running, I've got 14.5V at the battery...with lights, A/C, radio on, I'm reading 14.3V, although once the fans kick on, it drops to 12.96 for a split second, then back up to 14+V. I think problem may be solved! Thanks for all your suggestions!
