does somebody have a voltge tester
hi, i removed my tps before measuring continuity set by factory.
i installed tps onto a skunk 70 mill throttlebody and now need to set my tps to factory settings.
if someone could take a voltage tester or multimeter and test the tps on theyr car it would really help me out. measure continuity between the middle lead of the sensor and one of the other two leads of the sensor. only one pair will give you a reading. it should be between 600 and 1000. it is really easy and you dont have to remove anything accept for the plug on your sensor. thanks.
i hope im putting this in the right forum, if not please direct me
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
