Does S2000 has gas/fuel filter?
I just want to double check if S2000 has gas filter. I checked on the owner manual and gas filter is not in there. S2000 doesn't has gas filter right, anyone?
I think the S2000 actually has 2 fuel filters. Both are on the fuel pump assembly. One of them is the more common one that most modern day fuel pumps have - that sock thing at the very bottom of the fuel pump. The other one is further up the fuel pump and is somehow integrated into the assembly. I don't know if this is and easy change. The parts microfische lists both.
Sunder
Are you going to replace the fuel pumps yourself or you going to have the Honda dealer does it for you?
xviper
Where is the fuel pump? Under the bumber behind the passenger right?
xviper
