Does this looks like its leaking (Clutch)
OR.. your engagement adjustment could be off.. check the slave cylinder mounting bolts.
do a flush with new fluid. if fluid level drops over few hundred miles.. then you need a new master or slave.
my cluch pendal thingi looked the same as yours.. just wipe it down.. clean it up.. see if it comes back.
