does anyone know where this connects to?
does anyone know where this belongs, I'm pretty sure it's a sensor. I'm also guessing that the little tube im holding to the right connects to the little empty connector in the middle?
im also looking for a radiator hose diagram, does anyone know where i can get one without stoping by the dealer? thanks
That's a solenoid for part of the secondary air injection system. Have a look here:
https://www.s2ki.com/forums/index.php?showtopic=105368
That whole thing gets attached to anything solid that doesn't get the hoses in the way of the engine spinning parts. If you have a CAI, then it screws (or zip tie) into a little bracket that the CAI should have.
Normally it connects to the back of the stock air box.
The Comptech SC install instructions tell you to remount it on the vacuum tank (in front of the crossmember?) using a small bolt and spacer.
Originally Posted by advanracing62,May 26 2005, 05:27 AM
I believe it's called the EVAP purge solnoid- I took mine out. It is part of the emissions crap that is on the car- didn't notice a difference in testing.
It is a Vaccum solenoid for the Secondary air injection.
BTW, The emmisions crap keeps the air clean. Isn't that a GOOD thing?
AndyS2
10-15-2003 02:43 AM
