Does anyone know how to set timing using the cam gear marks?
I probably should've oedered the helms befor starting this project but . Anyone with a helms handy out there?
Thanks for the help
Tommy.
Thanks for the help
Tommy.
If you want to see what the timing is you can do this with a timing light.
If you want to set/change the timing mechanically, you can't.
Are you setting up an AEM EMS?
One of the valve adjusting screws broke during a valve adjustment and the cams had to be removed to change it. I needed to set the cam timing but I got it figured out with some help from G-s2k and his helms.
Thanks anyway guys,
Tommy.
Thanks anyway guys,
Tommy.
