Do you guys fully press down the clutch or just partially?
You shouldn't be moving the shifter at all until the clutch pedal is completely to the floor. You will trash the syncros and the clutch unless you do. Work on your shifting and pedal work and everything will smooth out. The travel distance does nothing for smoothness. It's smotther because you're dragging the clutch.
The proper shift sequence is precise: One - the clutch goes ALL the way to the floor; Two - move the shifter from one gear slot to the next (matching throttle), letting the neutral detent participate in the motion (don't rip it through the neutral gate from one gear to the next in one rough motion - it should be a rapid/quick and punctuated "click-click" sound.); Three - simultaneously coordinate the de-clutch and throttle.
All the way to the floor. Otherwise enjoy the pain and cost of replacing the effected components sooner than you should have to. I assure you you're not saving effort or time. It's just plain sloppy and lazy technique as well.
once i got in the s and drove it i was stunned,
shift 1/3 the way down and shift and everything hooks up nicely..
but i always been pushing it all the way all the time,
but once i shifted from 4th to 5th and didnt push down all the way and grinded gears
SO I ALWAYS PUSH ALL THE WAY
dont be lazyyy (:
dont be lazyyy (:
Thanks for the input guys! I definitely need to practice my footwork then.
1. clutch all the way down
2. shift gears (gently with very slight pause in neutral)
3. declutch and throttle
