Do timing chains need to be replaced?
#22
Since I'm at 120k miles, I've been wondering about this timing chain issue. Has there been any change on the thought of when it needs to be replaced?
The other issue I have is that I'm on my second short block which was replaced at 76k miles. What are the odds that Honda used a NEW timing chain when using the same head?
#23
I've yet to read on s2ki anybody having issue with a broken chain. Looks like you'll be the one telling the rest of us when/if it needs to be changed, joe.
#24
Originally Posted by Ludedude,Jun 16 2004, 04:41 PM
A good rule of thumb is about 100,000 miles to replace a metal timing chain in a normal street driven engine. Obviously cars with a lot of track miles should do this sooner. Being that this is an "interference" motor, if the chain breaks the valves will come into contact with the pistons and lead to a much more expensive repair.
#25
chains are basically good for the life of the engine. the only reason you'd replace them is when you rebuild the engine. the only thing that can go wrong with them is the links could stretch/deform.
#27
That's what I was thinking.
#28
Just a thought!
Drive Safe,
Steve R.
#29
Thanks for all the input! This is my first timing chain equipped vehicle and I just wanted to prevent the dreaded "timing-belt" disaster.
So who do I send the bill to when it breaks off and destroys my engine?
Owen_1987
03-12-2012 07:36 AM
W00LY MAMM0TH
02-23-2010 03:01 PM
