do i use royal purple or is it a waste?
i am wondering if i should go with royal purple motor oil and diff oil... is it worth it? also what weight oil should i use..i was going to go with 5w30 RP engine oil and 75w90 diff oil... just wanted some opinions on this
Best to dig around Bob is the Oil Guy:
http://www.bobistheoilguy.com/forums/ubbthreads.php
So I think RP is overpriced, and am going with Pennzoil Platinum 5w30, with factory intervals.
For the rear end - LE1605 because it make things soooo much quieter.
http://www.ricks2k.com/products/le1605.php
If you're going to pay that much $$ for oil, I'd go with the Redline.
If not, I heard the RP ain't that much different from mobil 1.
Costco has 6 quart boxs for $22 after $8 coupon.
Got one yesterday and changed mine.
Dan
Dan
I use RP I dont' think its that much more than Mobile 1. I believe RP is a L5 'true' syhn oil whereas Mobile 1 is only a l4 syhn.
in winter I use the recomended 5w40 for lower temps and in the summers i use the recomended 10w30. both have worked great for me so far.
