Do I NEED To Start It Over The Winter?
#21
i heard from someone once its bad on the bearings in the diff with no load but dont hold me to it.
#22
If you car is stored outdoors, it is a VERY GOOD idea to start it, and DRIVE it regularly.
-rotors are bare metal, and will rust. If the rust is allowed to penetrate the rotors, they are garbage. driving cleans them.
-batteries can run low on charge. If a battery on low charge is allowed to freeze, consider it 75% wasted.
-all metal parts, bearings, eng, trans, wheel bearings, everything...their only protection is a coat of oil or grease. Gravity, over time, will pull the oil down clean enough to let rust begin. I have pitted camshafts here due to long winter outdoor storage.
If you are indoors, not frezzing, sitting a few months is ok.
You are ABSOLUTELY doing no harm by starting and driving the car.
I dont recommend any start that shuts down cold. Moisture forms instantly on startup. Driving to operating temp will burn it off.
#23
People tend to overthink this too much IMO.
I live in Minnesota. Long winters. I usually store in Sept and drive again in April May depending on winter.
Stored on E85, I don't start it at all till I actually drive it. I have a tender on it, clean and vacuum it. That's it. That's all I have ever done on all of my cars I've stored.
#24
#25
Hi Been following this thread . Unfortunately, I had to garage my 02 S2K at the beginning of November for over the winter. My intention was to start monthly but due to unforseen circumstances , it had to sit until today but when I went to open it up and start it . However, The battery is now dead and the doors are locked down and I can't get into the car !!! Any ideas or suggestions !! oh, yeh I'm in Scotland and the winter hasn't been too cold !!
#26
#27
My car is stored indoors fom December to April. Garage is unheated, floor is covered with heavy plastic to lessen moisture transfer.
Not jacked up because I will be replacing the tires as soon as it goes back on the road.
It has now been started once and run for 15-20 minutes. I will do the same in Feb and March.'
I envy warm climate owners.
-jazzman
-jazzman
#28
#29
Originally Posted by trAP2' timestamp='1327614936' post='21355799
[quote name='S2K80bc' timestamp='1327614168' post='21355763']
Problem sorted with Master Key and half clip turn in door ! Okay !! I'm a girl !!!! Putting car on trickle charger and will faithfully start her every other week until she's back on the road in May . Thanks for the response.
s2kjoel
04-23-2014 06:47 AM
