Do I NEED To Start It Over The Winter?
Old 01-24-2012, 07:28 AM
Jazzman's Avatar
Default Do I NEED To Start It Over The Winter?
It was my intention to start my 2007 over the winter, today being the first try. I knew my battery was low and put a trickle charger on it when I put it away a month ago. Yes, it is the original battery,
Today, I reconnected the battery cable and went to start it. The lights came on, but not enough juice to crank it over. I put the trickle charger on and will try again tomorrow.
So, the question- Do I need to start it monthly as recommended in the manual? If so I need to buy a new battery now.
If not, I will wait until April when I intend to put it back on the road and then buy a new battery.
thanks,
-jazzman
Old 01-24-2012, 08:11 AM
speedjunky01's Avatar
No you don't the dry cold starts are bad for the motor
Do you want to do a lot of them or just a single one in the spring?
Old 01-24-2012, 09:45 AM
Jazzman's Avatar
if it's bad, why does the manual recommend it?
Isn't it bad for the various seals not to be started?
-jazzman
Old 01-24-2012, 10:34 AM
spets's Avatar
Start it, but don't just shut it off. Take it for a drive around the block and get everything warmed up.
Old 01-24-2012, 12:03 PM
supavinn's Avatar
n hit vtekkk a few times =)
Old 01-24-2012, 05:29 PM
jimi's Avatar
thanks,
-jazzman
It's best to drive it when ever possable or don't start it at all. As for trickle chargers they will kill the battery long term. Use a battery Tender. Keeps it at 12 volts at all times. http://batterytender.com/battery-ten...-at-1-25a.html
Old 01-24-2012, 06:12 PM
Jazzman's Avatar
I have a Battery Tender, sorry.
Will try tomorrow.
-jazzman
Old 01-24-2012, 08:22 PM
2003AP1's Avatar
I dont start my car all winter.
I remove my battery and put it to a battery maintainer.
Old 01-25-2012, 05:36 AM
Jazzman's Avatar
I got it started up this morning, barely
Letting it run 10-15 minutes then will put the Battery Tender back on and sleep it for another month, according to the manual.
If it hadn't started, I would have let it hibernate until April, but it did.
case closed.
-jazzman
Old 01-25-2012, 05:43 AM
s2000maniac's Avatar
case closed.
-jazzman
i'm willing to bet that you did more damage in those 10-15 mins then you have done since owning that car, but hey it's you car.
Quick Reply: Do I NEED To Start It Over The Winter?
