Do I need to replace these pulleys?
https://www.youtube.com/watch?v=2DDwVcrVv-w
There's a little play in the belt tensioner pulley. The bigger pulley beneath it (water pump?) is solid, but has an audible squeak when the engine was warm. I tried it again this morning (cold) and it was silent.
The tensioner pulley and the idler pulley will both have some play in them as they have bearings, I would say that is not excessive.
The squeak is from the pump as the pulley doesn't have a bearing, not sure what to say about that, if it isn't leaking from the weeper and it turns smoothly it might be fine for a while. Is it noisy when the engine is running ?
if it doesn't leak and it isn't noisy I'd leave it for now, it will surely let you know when it needs replacing IMO.
E4RTH WORM JIM
09-08-2017 11:34 AM
rocketman
05-18-2002 07:41 PM
