Do i need new bearing cap bolts?
Do i need new bearing cap bolts when reinstalling the crank or is it ok to reuse the old ones? I cant find any info that new bolts is required in the service manual but it cant harm to double check here.
Thanks!
Thanks!
From my understanding you use the same ones unless you go with like arp studs or something along that line. I have used the origanals on all the b series motors i built back in the day
No i was not talking abou thead bolts...on b series they offered studs for the mains....but i dont think they do on the s2000 you can use all your same bolts no need for new ones....
yeah all of the B and H series motors i have built i have always used the same bolts and i never had a problem, just make sure u soak them in oil before i put them in.honda motors are real good about using the same bolts but if it was an american motor then u would need to replace them.
