Do I need to cut the bumpstops?
I've installed the Koni yellows along with the KG/MM race springs. I have them set on the lower perches. Do I need to cut the bumpstops to give the shock more travel? Current drop is about 1.75"
Thanks!
Thanks!
1 Post
Not sure this helps but my GC coilovers instructions said to trim the bumpstops (there are 3 sections an I trimmed off 1 or 2 (can't remember off hand). Bumpstop can prevent your suspension from bottoming out and possibly damaging the shock. If you can't get a clear answer from KG/MM or a dealer, I would consider trimming the bumpstop but leaving part of it installed.
