Do I need the air pump with my mods...PLEASE HELP!
Ok so I have the Invidia cat-back exhaust with test pipe on the car. Thats it nothing else. And when I turn the car on the idle will make a woooooow.......wooooow.....wooooow.....woooooow... ..imagine that as the exhaust tone as if its on a beat...Honda says its cause of my air pump being broken. Although I thought I didnt need the air pump? Or do I? Can someone please give me some help so I dont end up wasting my money to fix the broken air pump.
Justin
Justin
Originally Posted by ChefJ,Dec 17 2008, 08:51 PM
Doesn't sound like it has anything to do with the air pump. Sounds like a sensor issue to me. When does it go away??
WTF?!?!?!
72 views an only 2 reply's? I appreciate ChefJ for answering me, doesn't someone else have any other advice as well? Im sure that im not the only one this has happened to....
And I have used the search button
i had a bad tps and it didnt sound like your symptoms. are you letting your car warm up properly? when i start mine, it high idles at like 2k for a minute or two then goes down to 900ish.
How old is your engine? has your ECU had time to learn itself or perhaps it had a bad learn? try resetting your ECU also and do a proper ECU learn. TPS will be a bi*ch to replace as you have to buy a new throttle body to replace it.
Also make sure your throttle cable isnt too tight. that might be the problem for the little gas high rpm thing.
for the airpump question...
air pump is not needed in the car for it to run normally. it is used only for like 30 seconds when you first start it. its an emissions thing. if you take it out, you will have a cel though. car wont go into limp mode either cause its an emissions piece. if you have the cel on, you wont know if there is anything else wrong with the car though. search around, you can find it for about 100 bucks here or on ebay. a bad airpump will also throw a cel
thanks scarface. i do let the car warm up properly and the engine is brand new. Every part of the engine is brand new. I will check on the throttle cable and resetting the ECU.
