DIY starter install revision...
Any tips on getting around the ABS and such as stated by the member above with the AP2? For example, do you pull out the front or from below while you are down under the car? I assume that you always go under, even with the AP2? Good to be in direct contact with you and thanks for all of your contributions. I have saved thousands due to your posts and advice.
CrAzYNeSs
04-16-2005 09:17 AM
