DIY: Replace dash light bulbs (AP1)
Old 12-02-2015, 02:56 AM
  #101
ice2k's Avatar
Thanks ROCKSTAR143! =)
Just one more thing though, if you don't mind sharing with us the part# for the hazard, roof, cruise, and defroster buttons.
Old 09-08-2016, 07:54 PM
  #102
sunk318's Avatar
Here are my 2 cents.
-The bulbs listed on the original post does not include the bulbs for "Cruise Control" and "Rear Defrost" buttons.
-It took me about an hour and half. If I were to do it again, it will probably take about 30-45 minutes. So this is a fairly quick DIY.
-Tools you need are various size of flat head screw drivers (to pry out plastic covers on top of speedometer and unscrew the bulbs out), a philips screw driver, and a 12mm socket wrench.
-There are 4 bolts that you unscrew with 12mm socket wrench. These are secured with some Hercules power so keep that in mind. I used impact wrench with 3 inch extension.
Hope that helps!
Old 09-08-2016, 08:28 PM
  #103
shrykhar's Avatar
Would also like to add that Qube Engineering has excellent instructions and pictures on how to get to the dash bulbs:
http://www.qube-engineering.com/Documentation.html
Old 09-12-2016, 10:17 AM
  #104
sunk318's Avatar
Wish I knew that before I took on this DIY.
FYI, the exact DIY needed for this project is at this link: http://www.qube-engineering.com/Documents/Qube'sLEDGaugeClusterInstructionsAP1_v1.1.pdf
Old 12-26-2016, 03:25 AM
  #105
E4RTH WORM JIM's Avatar
Any chance of getting the pictures working?
edit: /\ thanks
Old 12-26-2016, 11:02 PM
  #106
Grip Hrd's Avatar
edit: /\ thanks
No, I messaged the first poster not long ago, he mentioned that he had posted up on a previous server that is currently down and those pictures are no longer coming back. Goodluck, it is still a work in the process for me as well, needing to replace those dash lights. I'll come back and re-read this thread, and find those bulbs to fix those lights that arent working. hopefully sometime end of winter/spring.
Any updates with PICTURES, pleas share!!
Old 12-28-2016, 10:08 AM
  #107
Charper732's Avatar
Does anyone know the general bulb code for the bulbs used and if there is LED replacement options?
Old 07-02-2017, 07:15 AM
  #108
omgitsoop's Avatar
Seems like a lot of pictures are dead in all the old diy's, any way we can get an update on this?
Old 07-02-2017, 03:40 PM
  #109
shrykhar's Avatar
I'd like to point out again this this document from Qube Engineering does an extremely good job of documenting how to remove the dash:
http://www.qube-engineering.com/Docu...2_1.x_v1.0.pdf
They (obviously) provide a full LED-based solution, but not something where you'd plug the bulbs in yourself.
No, I am not affiliated with Qube Engineering.
Old 07-02-2017, 03:57 PM
  #110
shrykhar's Avatar
2005 S2000 S2000 MT Heater Control
79628-S2A-003
79670-SL0-A01
2005 S2000 S2000 MT Switch
35855-S2A-505 (replaced 35851-S2A-003)
brokenbird (12-20-2021)
Quick Reply: DIY: Replace dash light bulbs (AP1)
