The DIY Oil Change
Old 09-05-2008, 01:51 PM
  #61
Toki's Avatar
It takes about 20 minutes max to change your oil. Better than sitting around a dealership for hours. Also consider that oil changes usually are assigned to the least qualified tech. For $25, they are probably using the cheapest oil as well.
Old 09-08-2008, 05:09 PM
  #62
ahrmike's Avatar
88 bucks for oil change. 60 bucks for my redline ful synth oil. 20 bucks (14 with discount) for my oil filter.
Its easier to get the oil change bolt from the TOP of the engine...if your car is dropped and you cant get a jack under there. its very possible and doable. just a fyi!
Old 09-08-2008, 05:14 PM
  #63
jonmizu's Avatar
did you guys know that jiffy lube can do your oil change in 8 minutes? lol talk about service.. haha
Old 10-07-2008, 04:52 AM
  #64
s_d2k's Avatar
maybe u know how much is 5 quarts in liters?
and just to ba sure the best oil is 5w30 ?
thank u.
Old 01-01-2009, 06:24 PM
  #65
blah5's Avatar
great guide! It took me a while to do this because i couldnt find the drain bolt, but after viewing this wonderful guide, it was a cinch!
Old 01-15-2009, 09:18 PM
  #66
fr0ggstyl's Avatar
do i have to use a torque wrench for the drain and fill plug?
Old 01-16-2009, 06:06 AM
  #67
takeshi's Avatar
You don't have to but if you don't have a good feel for proper tightening it's recommended (don't under or over tighten). Good luck getting a torque wrench on the fill cap.
Old 01-25-2009, 05:55 PM
  #68
fr0ggstyl's Avatar
okay i just got a clicker torque wrench and i dont know how to use it help please
Old 01-25-2009, 06:05 PM
  #69
DBXFX's Avatar
turn the dial at the bottom to the number you want. make sure you are reading ft pounds. the bottom handle twists.
most of them arent reversible so you just hand tighten the bolt and then use the torque wrench to finish it off. the wrench will automatically click when the torque specis met and will not go any tighter, tada
Old 01-26-2009, 01:37 PM
  #70
fr0ggstyl's Avatar
Post
thanks i got it now
Quick Reply: The DIY Oil Change
