The DIY Oil Change
#152
Lmfao you're joking. Just buy an extra quart of oil and dump the whole quart in there. Reving an engine with low/no oil will cost and cause damage
#153
#154
#155
What do you guys use the remove the drain bolt? I tried last week and again this morning to get the damn thing off and it wouldn't budge. I used all the strength I could and it did nothing. After about two hours of trying I dropped it at the Honda dealer since I couldn't get it or the transmission bolt off, luckily they said they would do it for labor cost since I had the fluids and they promised they wouldn't overtorque the bolts.
#157
Received 1,753 Likes
Originally Posted by sse2k' timestamp='1357604559' post='22252013
Aside from the 2x4 method, are there recommendations for a decently priced set of low profile ramps?
http://www.fumotousa.com
#158
#159
Won't need ramps again with this. Fumoto valve. Love em. Change the oil with just the hood up. No more messing with the drain bolt. I have a 'pliers' style oil filter wrench that is fine, WalMart.
Next oil change, I'll put one of these on.
Chris
#160
Chris
Fumoto -- Disaster Averted -- Barely
Fumoto Valve Incident
Fumoto Drain Valve FAIL
