The DIY Oil Change
#112
Another question for you guys.
I only know of two jacking points for the S2000 and they're on the side near the front. Is there any way I can jack the car up directly from the front so that when I do the oil change, it's more leveled?
#116
As always, search is your friend:
https://www.s2ki.com/home/2010/05/10...up-your-s2000/
The center jacking points are discussed in threads as well.
#117
If you weren't/aren't using the center jack point, then how are you putting in your jack stands?
#118
get ramps if you're too low, then use center jack point, then put jack stands on both sides.
#119
Did it myself today just for shits... my car is lowered and it took me about an hour to do the entire job... saved like 5 bucks.
Honda service department - you can continue to do my oil changes, haha.
