DIY or Mechanic?
DIY or Mechanic?
So I recently got a valve adjustment and had a compression test before. The readings were 240, 210, 215, 240. Now I want to compression test again in hopes the low compression was due to the valves not closing all the way before the valve adjustment. Now I'm debating between whether or not I want to take it somewhere and spend the money for another compression test, or buy the gauge and battery charger to do it myself. I do enjoy working on my car and always want to learn how to do things myself, but I can't think of other uses for a car battery charger and gauge after I do the compression tests, except for more compression tests.
Originally Posted by s2000maniac' timestamp='1373961769' post='22668391
You don't need a battery charger for a compression test
I was worried by the time I get to the last cylinder, my battery would be weak and not crank as fast, making it seem like I have low compression.
Do a wet compression test to distinguish what is exactly giving you the low compression in those two cylinders.
To do this: drop a spoonful of oil into the spark plug chamber of suspected cylinder, then perform compression test as normal.
If the compression goes up significantly, than it is your piston rings.
molotovsoldier
03-09-2010 04:14 PM
