DIY KNOCK SENSOR
DIY KNOCK SENSOR
DOES OR HAS ANYONE HAVE A WRITE UP ON HOW TO DO IT AND WERE ITS LOCATED... IF PICTURES ARE AVAILABLE BETTER AND IS THERE ANYTHING I SHOULD BE CAREFULL FOR? LIKE OIL COMING OUT BECAUSE I HEARD ITS SCRED INTO THE BLOCK?
Well...this isn't Honda Customer Service. Bumping after waiting 90mins is not going to get you an answer faster. Wait at least 24hrs.
Also, all caps is a real turn off. If you are posting from a phone, then at least apologize for YELLING.
As for the DIY...it's easy...unplug the old sensor, unscrew it (no oil will come out), screw in the new one and plug it in.
It is #7 in the pic...
