DIY How to Fix O2 CEL
#21
Originally Posted by RBR,Jul 7 2009, 12:20 PM
actually the O2 sensor that went bad is the 1st one that's attached to the exhaust manifold, not the one after the catalytic converter. I'm not running a test pipe. Do you still think it's just fouled up? I may just pull it out to take a look at it first. if it's ok, do you think doing all this to that particular O2 sensor will help?
#22
By they way, I used Seafoam in the gas and some in via the intake vacuum hose and the check engine light went off in about 3 days after. Maybe I just got lucky, but this could be an option for some of you with the same problem.
