DIY clutch replacement - thread for all my questions/problems
#21
I was able to use my regular ratchet and the hex sockets already had. None stripped.
Trick I used is slid the driveshaft back (it will slide on cv splines) to gain clearance. Then socket would fit into bolt nice and square.
Driveshaft would creep back, but I just kept sliding it. Only needed to stay square while breaking them loose.
This trick worked for both front and rear driveshaft mounts.
#22
Received 1,418 Likes
Tip for pulling the trans without scratching the firewall.
After removing all the bell housing bolts, rotate the trans slightly clockwise (looking at the bell housing from the back of the car) before pulling it backwards, off the spline. Maybe 5 or 10 deg of rotation.
You'll need every single socket extension you can find in your city for removing or installing the bell housing bolts, BTW. Buy a couple of wobble extensions too. Basically, an extension setup that's longer than the trans itself.
Reverse is true for install.
windhund116 (04-10-2023)
#23
Success! Thanks for all the advice.
I got them all off clean with vice grips + a lower profile socket wrench and hex socket. It perhaps helped that I soaked them with PB Blaster a couple times and let that sit for a few days.
Although no matter how I contorted and aligned things, I still needed a wobble adapter -- the wrench head collides with the driveshaft preventing a straight-on connection with the socket itself. When I go to reassemble I'll perhaps get someone to pull and hold the driveshaft back for me... maybe that would give things just enough clearance, as otherwise I would have needed 3 hands to twist the socket + vice grips + hold back the driveshaft.
I'll probably return to this thread soon, as the next bit is the main attraction -- removing the transmission
noodels (04-19-2023)
#24
An impact and the right extension setup is the way to remove driveshaft bolts without damaging them.
Unless they're corroded in place.
#25
I ground down a standard hex bit and used an extension on an impact to get the driveshaft bolts out. Didn't strip a single one. I feel like people turn these particular bolts into a nightmare that simply didn't need to be had they had the right tools from the get-go.
Proper research is your friend. I'd never done a clutch in my life before I did the clutch in my s2000. Simply taking the time to read up on the particular & specific nuances of the job saved me a ton of headache, and not a single part of the job was "difficult" because of that.
windhund116 (04-19-2023)
B serious (04-20-2023)
#28
Once I approached the problem with the right tools and method, however, they all came off just fine -- except for the first one, but only because I was impatient. Live and learn.
I have been following a YouTube tutorial on clutch replacement and am aware of all the spots to grease... but verifying with the service manual is a wise move. Good point.
#29
I have a 3/8 drive hex bit that was too long for removal. But, I do want to use this one for re-install, as my torque wrench is 3/8 drive. I'll try cutting the bit down.. it's a long socket at 2" total.
#30
Good call. The 12pt fasteners are Class 12.9....so an extremely hard/strong bolt.
AP1 is M8x1.25 60 and 65mm
AP2 is M10x1.25. I think 60mm only (someone fact check me on this length)
With the larger thread and wrench/flange size on AP2 bolts...I wonder if the 12pt still fit and allow a tool to fit.
