DIY: Clutch Interlock Switch Bypass
Old 08-08-2008, 07:02 PM
  #81
jezzder's Avatar
Quite the example you are........
jezzder is offline
Old 08-08-2008, 07:34 PM
  #82
slipstream444's Avatar
Originally Posted by spectacle,Aug 8 2008, 08:28 PM
I never knew being a dick could be so much fun.
I have little doubt your right Jezzder - I don't believe he's active duty. Judging by the character of the posts - it's likely the individual posting is a pre-pubescent junior high school brat - probably using their Dad's login while Dad's away serving his country.
If the individual is active duty, his service probably mirrors the attitude you're seeing here - perhaps being processed out for the same attitude.
And you're right Jezzder - Military personnel have the obligation to act in a much more professional manner. I've been serving for over 20 years
slipstream444 is offline
Old 08-08-2008, 08:06 PM
  #83
Togobox's Avatar
i think if you press the clutch pedal, that actually unloads the clutch pressure plate springs , the leverage of the pressure plate is on the flywheel. the thrust bearings might have much more wears by dumping the clutch instead of releasing it. If the above modificaion is done, the cam shafts to unload the value springs should also be removed when engine shuts off to reduce valve springs/retainers wear. And to lift the wheels off the ground to reduce strut springs sage.
Togobox is offline
Old 08-08-2008, 08:08 PM
  #84
You're 180 out... but nice try at the theory though. I'm not being sarcastic.
It doesn't matter if it's a push or pull clutch, the constant load is maximum with the clutch pedal pushed in - that's a well established fact.
SpitfireS and I however disagree about the clutch dump issue. I think there is a shock load factor associated with dumping the clutch. I believe it's an acceleration related factor created by quickly unloading the thrust load that can shift the force momentarily - opposite the thrust washer. However, this momentary load shift likely has minimal wear consequence due to the fact it's relatively short lived.
Old 08-08-2008, 08:09 PM
  #85
Slows2k's Avatar
Start playing nice before this thread gets ruined with crap.
Slows2k is offline
Old 08-08-2008, 08:11 PM
  #86
Togobox's Avatar
so you think by dumping the clutch won't hurt the thrust bearings right?
Togobox is offline
Old 08-08-2008, 08:21 PM
  #87
Slows2k's Avatar
Cool, I'll just lock it to prevent the crap from being FAQ linked.
Slows2k is offline
OneSilverS2k
04-22-2022 06:52 PM
jwzimm
04-09-2021 05:44 AM
arian_ma
11-30-2007 04:50 PM
f00dstamps
02-08-2005 08:45 AM
BlitzSRM
05-13-2004 05:34 PM
Quick Reply: DIY: Clutch Interlock Switch Bypass
