DIY brake Bleeding
#74
Originally Posted by B.Money,Jan 15 2008, 08:33 PM
can this same method be used on the clutch? a gravity bleed?
#75
Originally Posted by INTJ,Mar 24 2008, 09:33 AM
You are killing me. I've been around there and they are lucky to have any brand brake fuid...
#76
Originally Posted by moogleii,Jun 12 2008, 06:00 PM
Hygroscopy. Dot 4 is more hygroscopic than Dot 3, and both will absorb water from the air.
#77
I would suggest flushing the OEM fluid every couple of years. I would suggest flushing DOT4 fluid every year.
There is absolutely no benefit to DOT4 fluid unless you track the car.
#78
DOT3 and DOT4 fluids have almost identical composition. Different companies have different additives to raise dry or wet boiling points. However, since DOT4 has higher wet boiling points than DOT3, it requires less moisture absorbed to bring DOT4 fluid out of spec.
But if Honda recommends DOT3, putting in DOT4 doesn't mean you have to change it any more often than you would normally. It'll fall out of DOT4 spec earlier, yes, but that's why Honda spec'd DOT3 in the first place.
#80
Originally Posted by terahertz,Jun 12 2008, 12:26 AM
two weeks?? i'm on rbf600 and it's been in there for at least a month and i'm going to my second track day on it on friday!
http://twincamtech.stores.yahoo.net/motbrakfluid.html
For everyday driving, we recommend using Motul D.O.T. 5.1 brake fluid. This is an excellent brake fluid to use when upgrading your brake system with braided stainless steel brake lines, brake pads and sloted rotors. It can be mixed with SAE J 1703, D.O.T. 3, 4, and 5 synthetic brake fluid. Motul D.O.T. 5.1 brake fluid has a 509
