DIY brake Bleeding
Old 01-12-2011, 06:32 AM
  #191
JEEBS's Avatar
If you pressure/power bleed the brakes, can you use the method that Billman posted as far as which areas to bleed first?
I would gravity bleed but I ordered a Motive power bleeder and going to try that first. I have very low patience and the gravity bleeding method would drive me nuts.
JEEBS is offline
Old 02-11-2011, 07:50 PM
  #192
OneSilverS2k's Avatar
Originally Posted by Billman250,Apr 22 2007, 05:22 PM
I bottle of ATE Super Blue is surely enough to do the entire car. You'll use 3/4 -7/8 of the container.
By trial, I've found the best sequence is RF, LF, LR, RR.
Empty the master with a turkey baster.
Crack the right front bleeder, the level will start to drop. Get it a little lower, but not enough to suck air.
Fill the master to the very top with ATE blue.
Start with the right front bleeder. Attach a clear hose, and let it gravity bleed till it turns blue.
Repeat for the remaining wheels.
You'll have such a great brake pedal from the gravity bleed it will feel like the pedal is welded to the car
I have used this procedure on countless s2ks.
Any suggestions for a brake system that is off the car that will go back on? I am going to flush the lines that are on the car with air first, then reconnect everything.. but do I just start filling up everything and then do your procedure?
OneSilverS2k is offline
Old 06-17-2011, 09:58 AM
  #193
starchland's Avatar
I just used this method. Its like the slow drip method for coffee brewing, for the best flavour
starchland is offline
Old 10-21-2011, 01:21 PM
  #194
avarela86's Avatar
ISSUE: Leaking Brake master Cylinder @ cap.
BACKGROUND: I had replaced pads, retracted pistons and sucked out some fluid so as to not spill and drove a round a few days. Found that the reservoir sock was wet and checked from where it was leaking, added fluid and cleaned the area with brake cleaner. Last night had the brake light on consistently till I would accel quick which meant it was just low. Checked again and it was near low level so I added fluid....today I check again and what do you know fluid has spilled again. it looks like it is coming straight from the cap. is this possible? It is not overflowing but it is the same fluid that the car came with.
POSSIBLE FIX:Read through this whole thread now for the second time and will be doing Billmans ATE SB Gravity bleed as a test to see if I have an issue with my fluid.
I open the floor to you all! :-)
avarela86 is offline
Old 11-14-2011, 11:57 AM
  #195
Croc's Avatar
Billma is great as ever
how much time does it take?
Croc is offline
Old 12-17-2011, 01:30 PM
  #196
berlina2ks2k's Avatar
I changed the front rotors and pads today and performed a gravity bleed for the first time today. Unfortunately my dumb**s decided to bleed the brakes in the wrong order. Instead of following Billman's order, I accidentally did LF, RF, RR, LR. Is there's going to be a major disadvantage to having done it in that order?
berlina2ks2k is offline
Old 12-17-2011, 06:37 PM
  #197
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
it won't cause any issues, that's the recommended order listed in the service manual, I've done it both ways and they both seem fine.
zeroptzero is offline
Old 12-18-2011, 04:42 AM
  #198
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Starting with the RF allows more fluid to be drained from the master before new stuff is added. Theres a section in the front of the mater that cant be reached with a turkey baster or drain tool.
Did the LF yield the same result?
Billman250 is offline
Old 12-19-2011, 08:53 AM
  #199
All the brake lines cleared up after they were bled for a little bit and looked like fresh fluid by the time I closed the bleeder and moved to the next wheel. I didn't use Super Blue so it was a bit harder to tell but from what I saw it all seemed fine. Just wanted to double check.
Thanks!
Old 04-01-2012, 02:38 PM
  #200
RedCelica's Avatar
Just did this and big props to Billman for the suggestion. Took about 2 hours, but I still have almost half a qrt. of ATE left over...time to do the DD too tomorrow
RedCelica is offline
Quick Reply: DIY brake Bleeding
