DIY brake Bleeding
Old 11-08-2010, 12:59 PM
  #181
irv_usc's Avatar
so basically you pressure bleed instead?
irv_usc is offline
Old 11-08-2010, 05:43 PM
  #182
Supra-holic's Avatar
Correct.
Supra-holic is offline
Old 11-08-2010, 07:21 PM
  #183
s2000maniac's Avatar
i did gravity bleed for my clutch and was suprised of how quickly the fluid came out when i opened the bleeder..... i think some air got in the system coz the clutch feels "soft"
I may have to try it again with someone pouring the fluid in while i open the bleeder
s2000maniac is offline
Old 11-14-2010, 08:33 PM
  #184
zakiu's Avatar
Just did a gravity bleed on mine. Order I used was from the shop manual. LF, RF, RR, LR. Speed was so-so. Driver front took under 5 minutes to gravity bleed out. Passenger front was almost as quick. However Rear Passenger took a while, at least 20 minutes, more like 30. I let the Rear Driver go on its own for 15 minutes then pedal bled the rest.
Car is an '00 at 45k on its original fluid. Switched to ATE Super Blue. Pedal feel was good. Pedal feel is still good, maybe a little stiffer under medium-hard braking. Not sure.
I'm wondering if the rears were slower because the front was not elevated when the rear was elevated. It literally was 2 drops per second in the rear. From here on I'll be gravity bleeding the fronts and then pedal bleeding the rears.
zakiu is offline
Old 11-15-2010, 09:23 AM
  #185
chuhsi's Avatar
Anyone know if I can I gravity bleed a front BBK? Originally getting bubbles out of those calipers with manual pumping was a huge PITA
chuhsi is offline
Old 11-15-2010, 10:39 AM
  #186
s2kAtTracks's Avatar
Should be able too.
s2kAtTracks is offline
Old 11-29-2010, 11:33 AM
  #187
mr5parkle's Avatar
i think i only used 1/2 of liter. i can't really tell since the ate blue can is tin. but is it abnormal to use so little?
when i bled the brakes, all four corners eventually turned blue but i probably only added maybe 1.2 reservoirs worth of fluid.
mr5parkle is offline
Old 11-29-2010, 11:57 AM
  #188
If it didn't start blue and is blue now, you are good.
It will vary on how much is used, so you should be perfectly fine.
Old 11-29-2010, 02:45 PM
  #189
Banned
CapoArgentino's Avatar
I did the same and what was left over was even enough to flush the front and rear brakes on my sport bike and I still had some left
CapoArgentino is offline
Old 01-11-2011, 09:46 AM
  #190
dimitry8's Avatar
I think the rear elevated when the front wasn't has a lot to do with the time it took you to bleed the lines.. remember you are using gravity to bleed the brakes, which means you were working against it... and I also think Billman's sequence helps too.
dimitry8 is offline
Quick Reply: DIY brake Bleeding
