DIY brake Bleeding
#164
Originally Posted by Billman250,Oct 8 2010, 07:13 AM
If you need to ask that than this is not a DIY. Especially when dealing with brakes.
This writeup is already really straight forward. If you can't figure it out from there you probably at least need someone that knows what they're doing with you. Brakes are sort of important.
#166
Can I use the Super blue for the clutch also?
And the gravity method is used for the clutch too right?
clutch:
-open valve
-bleed down the reservior
-close valve
-fill reservior
-repeat until I see clean fluid
correct?
clutch:
-open valve
-close valve
-fill reservior
correct?
#168
Its not hard at all, but if you are not comfortable then yea let a shop do it. But, if you are in CA I'm sure there are more then a few members locally that could help and show you.
