DIY abs sensor
Do you mean an actual sensor build or just swapping them for new oem ones? Swapping them is easy. I can't give you specifics, but they are held on the hub with one bolt, and then various other bolts secure the wire up to the connector. Just remove all the bolts, unclip the connector, and reverse to assemble.
EDIT: Just checked the HELM manual. It's like I said. 4 bolts secure the sensor and the cable. The cable goes through a grommet under the fender which I'm pretty sure goes into the trunk. You should be able to access the connectors by pulling back either side of the trunk trim. I may have the manual upside down though, so eyeball the grommet to see where the connector goes.
