Displacement with .25 oversized pistons
Does anyone know what the final displacement would be for an F20C running factory 0.25 oversized pistons?
2009cc vs 1997cc stock
Essentially nothing... If you are that deep in to the motor... with 14.5psi coming soon... why not go sleeved? 14.5psi you 'll need it!!!
Originally Posted by steven975,May 13 2006, 05:12 PM
with that kind of boost, it is doubtful you will be able to run anything over the factory bore.
have you seen how thin the walls are between cylinders?
Laskey says 89mm bore is wonderful for anything but a drag racer pushing 50lbs of boost. He has now done 3 - 89mm bores for boost... all successful!!!
Oxnard is not too far away from Earl!!!
