Dipstick popping up?
![Arrow](https://www.s2ki.com/forums/images/icons/icon2.gif)
I have noticed that after I go out driving around in VTEC, and not just cruising, that the dipstick will not be sitting flush against the valve cover anymore. It only comes up about 1/4" and doesn't leak anything out, but I am wondering if this is a problem that anyone else has experienced, and if so, is there a fix?
I was thinking of getting some thicker o-rings to replace the two green stock ones, to increase the grip, and maybe keeping it installed correctly.
Any ideas?
Thanks!
Any ideas?
Thanks!
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
this is from excess crank pressure. I just had the same problem and took mine in under warranty. They did a leak down test and found 2 cylinders under 30 and 2 over 40. I have the car back now after getting new piston rings and a full top end gasket kit. You may want to get this checked out. It could also be the pcv valve or a faulty dipstick, but none of this solved my problem. PM me for more info. My car was in the shop for 3 weeks.
1 Post
Did they tell you what caused the ring failure? I have the same problem (popping dipstick) and replacing the PCV valve has not helped. I am going to be pissed if I need new rings on my 14k MY 03 S2000.
![thumbsdown.gif](https://www.s2ki.com/forums/images/smilies/thumbsdown.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
I've had the same problem since my first oil change on my MY04, so I think the majority of the cars with this problem are not suffering from worn rings. It's just a design flaw of the dipstick.
the didnt say my car ran very strong and even slowly walked away from an MY01 from pre vtec. I would consider getting it checked out. I have the problem ever since i got the car at 11,300 miles
what is crank pressure? I know what oil pressure is, but crank pressure? And when you find the oil dipstick, find where is the crank dipstick is too, Alexf20C.
