Dimensions of Apexi VAFC??
Does anybody have the dimensions of the Apexi VAFC control unit? I'm trying to figure out where I would put it if I got it.
Also, by any chance, anybody in the MD area that has one installed?
I pur my APEXi RSM (almost same size as the VAFC) on the radio flap..have a look when u have it down...it angles nicely at the end and i just put some double sided tape at the base to hold it...and blutack behind just to keep it steady
Originally posted by RT
No vertical display option
It will fit in the dome light hole... I checked. I saw a Prelude with it installed like that. You can get some more info on it, including painting it black (to match the interior) here:
http://www.ntpog.org/mods/fifth-afc/afc.shtml
The "radio door flap" idea sounds pretty good to me- if it fits. It's about 1" thick, if I remember, max. On that page I also wrote up how to make a DIN (radio) mount for it.
Thanks for the link Marcucci, will you be making a harness for it, or splicing the cables? The only thing holding me up right now is this harness problem. I'll try to see if there is a way to build one with scrap parts or whatever this upcoming week.
Originally posted by 4igs2000
Fits where your deck goes too!
where do you run your wire to? I pulled my dash and ran it into thedash right behind the center heater vent. cleans it up a little. no dangling wires.
