Difficult reverse engagement
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
IMO its just the way the S2000 gearbox is after it has about 25-30k mi wear - notchy and not easy to get into reverse when cold. I've regreased everything, done the burr trick, chnged fluids, etc. I think its how the synchros wear and the fact that reverse is not always aligned just right.
Banned
![](https://www.s2ki.com/forums/images/s2ki/ranks/banned.png)
Ill give the first then reverse a try, im also going to rebleed the clutch because im not sure that I properly bled it when changing the master and slave cylinders. It shifts ok most of the time, but its mainly reverse on a cold start.
Banned
Changed all fluids, tried many of the above tricks and its still hard to get reverse while cold... I think Saki is correct here. Could just be the wear on the AP2 synchros after some mileage I guess?
Me too with the hard to get R gear. 2009 w/12k miles. I clutch into 3rd then push down the shifter and go for R. Works well for me. I had to do this on my 95 civic w/230k too. My 04 Odyssey thunks into R - with 102k on the clock I think I'm already ahead of most other 2nd gen ODY owners.
![0008.gif](https://www.s2ki.com/forums/images/smilies/0008.gif)
No way. I have 100k miles on my ap2 trans.
95% of troublesome shifting or notchiness in the trans can be blamed on dirty clutch fluid, poor rod adjustment, or a rusted input spline. It is rare if it is the trans itself.
Sad to say, if the trans has never been out, and no one cleaned the splines with a wire brush and greased them, then you have rust.
Honda did not grease it from the factory.
![](https://www.s2ki.com/s2000/uploads/gallery/1155735322/gallery_12160_15242_123973534744e507e3b0399.jpg)
Banned
This can be reached from the slave cylinder hole cant it? I noticed it was that same coloration when I changed the slave cylinder
Banned
Ok found a video and seems that part is reachable but could be a huge PITA to get to from that hole
http://www.youtube.com/watch?v=2GkWdHfFkjk
