Differential Fluid Used Oil Analysis Results for LE1605 (SAE110)
If you live in the States, Rick's or Mag-hytec can help you with purchases by the quart, A better idea might be to find out who a LE customer might be that lives near you from a LE distributor that has your territory. They might be more than willing to sare a 24 qt case with you.
Thanks for sharing your results JFusion! I've been using LE1605 since I got my car, and was thinking of changing it up next time, but guess I'll stick with it! The stuff is incredibly thick/nasty stuff, but I guess it works.
Is there a certain oil you like/use/had good results with? I've been sticking with good old castrol gtx 10w30 and just make sure to change it every ~4k miles or less, depending on track usage.
As far as motor oil goes, I had some good results on my latest used oil analysis running Castrol Edge Titanium 10w30, that seemed to work really well and I was quite impressed. I also run Amsoil 5w40 Full SAPs formula, I might have a used oil sample from this oil next year. I like the signature series Amsoil 10w30 and 0w30 but I haven't run them personally, just seen some good results from people running those oils.
Destiny2002
02-09-2004 12:41 PM
