Differential Fluid Change
Old 02-28-2012, 09:54 PM
  #261
Arthas's Avatar
Great write up, first time with a rwd car, so fire time doing this Tomorrow I will be heading to honda for the washers (hopefully) and after that ill head to pepboys and get the diff fluid and pump, at my work they are getting rid of the mobile 1 gear oil to replace it with Peak, so last I checked they were on discount prices + my disccount. Maybe ill stock up! Wish me luck
Old 02-29-2012, 09:52 AM
  #262
Arthas's Avatar
Went to pepboys picked up same pump as OP ,1 qrt of mobile 75w-90and 24mm socket , I couldn't find a 23mm, so I tryed a 15/16, that failed! So I'm glad I didn't take out the drain plug first, because now I'm going to have to wait for ammazon to ship the 23mm socket. Btw I went to 4 diffrent autoparts stores and no luck finding a 6point 23mm so ammazon was my only source for 15$. I went to dealer for washers and the part #s you guys posted did not match with what honda wanted to give me. I told him I wanted (904o2-pcz-003) &( 9o401-pcz-003)
Old 02-29-2012, 10:51 AM
  #263
dwight's Avatar
It was a little bit of a loose fit, but a 24mm worked fine for me. Given the size of the fastener and the low amount of torque required, I'm not concerned with rounding the corners of the nut. It's tightened to 33 ft-lbs so it can't be that hard to break loose. By comparison, a crank pulley bolt head is smaller and fastened to a much tighter spec.
If I had to do it again, I'd pick up 24mm combination wrench for the fill plug.
Old 03-01-2012, 07:14 PM
  #264
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
I find a 23mm box end wrench works best, I couldn't get a socket in there to loosen the fill bolt, a 23mm box end is usually going to be pretty long so you can get enough torque to break loose the fill bolt pretty easily. That size wrench should be easy to find too.
Old 03-01-2012, 09:37 PM
  #265
dwight's Avatar
I was having a little of trouble just using a 12" adjustable wrench, but a couple of light taps with a dead blow hammer and it came loose easily.
Old 03-03-2012, 01:18 PM
  #266
Selah777's Avatar
Had a little trouble with the fill bolt as well. Ended up cutting the socket in half to make it ultra shallow. Still awkward getting the wrench up there. But it worked
Old 03-03-2012, 01:36 PM
  #267
fernando.'s Avatar
Originally Posted by dwight
Are my drain and fill bolts in the each others' holes?
[url="http://www.flickr.com/photos/dwightsghost/6937083109/in/photostream/lightbox/"][img]https://farm8.staticflickr.com/7197/6937083109_151679bb0d_z.jpg[img][url]
Do you use a socket and ratchet for the fill bolt? I couldn't figure out a way to fit mine and ended up using an adjustable wrench.
Yeah, the bolts are switched.
Old 03-03-2012, 04:54 PM
  #268
DallasAp1's Avatar
whats the significant of changing out the washer?
sorry if that was answered i didnt read all 11 pages
i blew it off on mine and just re-used ill proly just buy new ones next change
edit: read more pages of thread came to conclusion im fine. my washer was in fine condition my car had 24xxx miles the diff fluid looked like mud so it was proly its first change. as long as it is not crushed its fine to be re-used is my final decision. if it beings to leak i will notice and easily solve the problem anyway
Old 03-03-2012, 07:16 PM
  #269
dwight's Avatar
Thanks. I was pretty sure that was the case and swapped them when I put it back.
Old 03-03-2012, 08:40 PM
  #270
rugsr's Avatar
How do u guys jack the car up to change the diff fluid?I'm lowered 1" and it always seems to be a pain to get under
Quick Reply: Differential Fluid Change
