Differential Fluid Change
Old 08-18-2010, 03:16 AM
  #181
jamesbrake9's Avatar
Too nice.
Old 08-19-2010, 07:01 PM
  #182
Bror Jace's Avatar
"so do you recommend Amsoil or Red Line? Any other US brand?"
I'm not sure of any other brands other than Amsoil in 75W-110. I think their "Severe Gear" oil is a solid differential lubricant and it's hard to go wrong with that one.
Some people swear by Red Line Oil, others swear at it. I used to be a fan but I've come to the conclusion that others products are better ... especially considering the price.
Old 09-03-2010, 12:38 AM
  #183
Opc
Opc's Avatar
you use 1 bottle of the mobile 1 75w-90 right, thats like .68 qts or something?
Old 09-03-2010, 06:27 AM
  #184
idea-catalyst's Avatar
Easy, cheap, throw-away pump solution: Use a short (18-24") piece of tubing. Remove cap from oil bottle. Drill a hole in the center of the cap slightly smaller than the tube and cram it through the cap so that the bottom of the hose just reaches the bottom of the bottle. Put the cap back on the full bottle, insert top of tube into fill hole. Squeeze and release the bottle until diff is full.
It's easier if the oil is warm. If you want to make it easier next time (in exchange for cleanup this time), drain the hose (still in the cap) and soak it in soapy water. Rinse, dry, and save for next time. (It's easier to clean a hose than a pump - or just hang it up to drain.)
I can post pics if someone is interested, but it's pretty easy.
Old 10-07-2010, 04:33 PM
  #185
jdmtite-s2k's Avatar
Does anyone know what diff oil I should be using if I'm running an aftermarket diff such as a cusco, mugen, or ASM... Thanks
Old 10-08-2010, 02:16 AM
  #186
INDYMAC's Avatar
I would start with what the manufacturer recommends first, then make adjustments as necessary.
Old 10-15-2010, 12:50 AM
  #187
GPWSIM's Avatar
hey guys i know the diy and the manual says keep the vehicle on a level surface during this procedure. If I only have a pair of jackstands to raise the S from the rear, would I encounter any issues doing it this way?
Old 10-15-2010, 01:22 AM
  #188
starchland's Avatar
I wouldnt sweat it. Thats usually how I do mine and I have had no problems. Its probably only about 50 ml more.
Old 10-15-2010, 07:18 AM
  #189
TougeS2k's Avatar
Well you can overfill the pumpkin. I hear your supposed so let the oil gush out of the fill hole while the car is level, that means its full. If you have the car up on one side you may be prone to over-filling it. Also it may be hard to completely drain the pumpkin.
Old 10-15-2010, 09:28 AM
  #190
irv_usc's Avatar
i wouldn't get under the car with just two jackstands.
accidents can and have happened.
besides that touge is right. you won't get all the old fluid out.
Quick Reply: Differential Fluid Change
